2000 Nissan Maxima Cold Idle Problem
BOSCHEY
2000 maxima 120000 miles that won't idle when engine is cold.
has been in and out of the nissan dealer. replace the computer, fuel regulators, fuel pump. no check engine light. sounds like it back fires through the intake. please help
Nov 3, 2007 at 2:39 AM
BLACKOP555
  • 10,386 POSTS
check the and clean the MAF and IAT with aresol cleaner. do not touch the MAF's wires or you will break them off. you can clean the iat with the same stuff but you can be a bit more abrasive with it. if those dont work then check the coolant temp sensor and sending unit.
Nov 3, 2007 at 8:15 AM
Suggested Repair
Clean the MAF and IAT sensors with aerosol cleaner, without touching the MAF wires. If that does not help, check the coolant temperature sensor and sending unit.
Conversation Summary
A 2000 Nissan Maxima with 120,000 miles will not idle when cold and seems to backfire through the intake. The dealer replaced the computer, fuel regulators, and fuel pump, and there is no check engine light. The expert recommends cleaning the MAF and IAT carefully, then checking the coolant temperature sensor and sending unit if cleaning does not fix it.
