1987 Nissan Maxima Ignition Bypass
CARDUDE2705
I have a 1987 Nissan Maxima, 6cyclinder manual. I was wondering how I might bypass the ignition switch (hotwire) until I'm able to figure out how to get the shear bolts out?
May 1, 2007 at 8:08 AM
  • 75,988 POSTS
Toggle switch between the battery positive terminal to the ignition coil. To power the igntion system
Push Button between the battery positive terminal and the solenoid terminal. To crank the engine over
Hope this help
May 1, 2007 at 11:09 AM
Suggested Repair
Until the ignition switch shear bolts can be removed, use a toggle between the battery positive terminal and the ignition coil to power the ignition, and a push button between battery positive and the starter solenoid terminal to crank the engine.
Conversation Summary
The owner of a 1987 Nissan Maxima six-cylinder manual asked how to temporarily bypass the ignition switch until the shear bolts could be removed. The expert suggested a toggle from battery positive to the ignition coil to power the ignition system and a push button from battery positive to the solenoid to crank the engine.
