i have nissan maxima 2003 j 3000cc milage 100000 the car engine got high temp. problem ,water level ok ,no leak ,oil ok ,cooling fan ok
Jul 23, 2007 at 9:35 PM
Remove the thermostat and test whether the engine cools normally without it. If it does, replace the thermostat. Do not leave the thermostat out, because it controls engine temperature and related engine-management functions.
The owner of a 2003 Nissan Maxima with about 100,000 miles reported high engine temperature despite normal coolant level, no leaks, normal oil, and a working cooling fan. The expert advised removing the thermostat as a test and replacing it if the temperature improves, while warning not to operate the car without a thermostat.
