Nissan Maxima Overheating
SHUMWAY04
I'm at my wits end here my car is overheating it's not smoking however the temperature gauze says it's running hot and at times the car will jerk. I've replaced the radiator in January and I can't see any leaks. There is still coolant in my overflow bottle however I have to continuously pour coolant directly into my radiator! I will drive maybe 5-10 minutes then almost immediately my temperature gauze will shoot directly to the extremly hot signal. Any idea why?! What are signs that it may be a possible waterpump?
Make - Nissan Maxima
Model-GXE
Mileage - 134,000
Engine Size - 3.0
Aug 14, 2007 at 12:57 AM
  • 75,988 POSTS
[quote="shumway04"]Hi,
Model-GXE
Mileage - 134,000
Engine Size - 3.0[/quote
Remove radiator cap start car if the coolant is swirling around the water pump is okay-Try replacing the thermostat and then comeback when it continues.
Do you hear the cooling fan when it turns On?
Aug 14, 2007 at 2:14 AM
Suggested Repair
With the radiator cap removed, start the engine and confirm the coolant is circulating. If it swirls, the water pump is likely okay. Replace the thermostat and verify that the cooling fan comes on.
Conversation Summary
The owner of a Nissan Maxima GXE with a 3.0 engine and 134,000 miles reports rapid overheating after short drives, occasional jerking, and having to add coolant directly to the radiator despite a recently replaced radiator and no visible leaks. The expert advises checking coolant circulation with the cap off to assess the water pump, replacing the thermostat, and confirming that the cooling fan operates.
