Cost of Radiator Hose? 1990 Maxima. $100 too High?!
JFREDRICHS
My radiator hose has a big hole. I only drive to the bus stop and to the store so I've been lucky for the past month(s). Conrads estimated $100 for repair. Is this fair? $59 for hose / $29 for labor / $9 for antifreeze .., one other cost I do not recall. I've been told this is too high. Any suggestions or comments on how I can get this cost lowered? Obviously, I am not a car person...
Jan 14, 2006 at 10:38 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
For a comparable estimate, compare the total installed price, included coolant and warranty terms. Arrange repair of an active coolant leak before further driving, and do not open the cooling system while hot.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
PALOMA PAUL
  • 14 POSTS
Sounds a little high, Are they a reliable garage? Do they warranty their work? They are definately marking up the cost of parts. Call a couple auto parts stores and get price quotes for the hose. See if there's a garage that will put on parts you have already purchased.
Jan 16, 2006 at 8:21 AM
JFREDRICHS
Thank you, Paloma Paul, for the suggestion to pre-buy parts and have them installed. I never thought of that, but it's an excellent idea that I will pursue; don't know if they'll go for it, but it is definitely worth a try .... Just an FYI -- I had the radiator hose installed at the Firestone place just across the street. The parts were less expensive by half, but the labor charge was doubled, so it ended up costing the same. (Think I'm in the wrong business!)
Jan 16, 2006 at 11:02 AM
Discussion summary
The owner of a 1990 Nissan Maxima asked about a radiator-hose replacement estimate after reporting a large hole in the hose.
Reported outcome: The owner reported having the hose installed at another shop. Lower parts pricing was offset by higher labor, leaving the total about the same.
The prices are historical figures from this discussion, not current estimates. The owner did not provide a post-repair leak check or report on engine condition.
Read the original discussion
