1992 Nissan Maxima Radiator
146,856 MILES • 6 CYL • 2WD • AUTOMATIC
BONRUSTY
I have a Nissan Maxima 1992. The radiator nipple is leaking, I keep it full of anti-freeze and keep a close eye. It seems to start losing power and then gets it back. when i push on the peddle slowly. also it will leak on the ground a little them it will be wet inside the cars front floor boards. Help is you can Bonnie
May 23, 2008 at 3:42 AM
  • 31,937 POSTS
Hi there,
I would concentrate on getting the coolant leaks under control first, you will need to get a pressure test don on the cooling system. I feel you may have a leaking heater core.
Mark (mhpautos)
May 24, 2008 at 1:10 AM
