2003 Nissan Maxima Alarm System or Fuse problem!
2003 NISSAN MAXIMA
61,000 MILES • 6 CYL • FWD • AUTOMATIC
GOODNES
Ok! Last night I was going to replace my dome-light in my car and I don't know how but I stick a scrue-driver inside and :
-my dome-lights are gone:
-my shift is locked:
-my alarm system is not working:
-I can open my trunk, only if I turn the engine ON:
-my door locker does not work:
I tried to find the problem but with no luck. I have checked all fuses that I know witch are fine, exept one-"ROOM LAMP" that I have replased.
If you could just tell me how can I fix it or what happened?
May 14, 2008 at 9:14 AM
  • 31,937 POSTS
Hi there,
yes this will cause the system to run hot, as it has a leak and apart from loosing coolant it will not run at the correct pressure which will be a factor with overheating as well, get it fixed before you do some more serious damage to your engine.
Mark (mhpautos)
May 14, 2008 at 2:33 PM
