1998 Nissan Maxima Digital Clock, keyless entry, alarm, pow
130,000 MILES • 6 CYL • FWD • AUTOMATIC
DURANGOMAN
The digital clock, the keyless entry and the alarm are not working. The power antenna has been removed, but the wiring is still intact, all leads have been taped. I have checked all fuses under the dash and the ones under the hood, and even replaced the relay in the trunk, but I still cannot get the clock, alarm and keyless entry to work. Can you assist?
Mar 12, 2008 at 12:58 AM
2CARPRO JACK
  • 11,533 POSTS
Did you test the fuses with a test light or meter, check the fusible links too? Looks like it may be a problem with the BCM if all fuses are good. Power for keyless and alarm and clock all go through BCM
Mar 23, 2008 at 1:12 AM
