Knock sensor replacement
2CARPRO JACK
  • 11,533 POSTS
Start by having the PCM scanned to see if it has recorded any failures in the engine management system.Then test the fuel pressure to be sure it is up to spec...should be between 34-44 psi at idle, engine off.Also need to use a manual fuel pressure gauge to see if the pump is bleeding down overnight causing this.
https://www.2carpros.com/dia/test_fuel_pressure.htm
Tuesday, August 6th, 2019 AT 3:25 PM (Merged)
