2002 Nissan Maxima Fuel Rail Leak
TSREDSOX
I accidentally removed the fuel rail and it is now leaking gas. It is a 2002 Maxima with about 50000 miles and has a V6 in it. The car won't start and spit gas out of the valves on the fuel rail. Did I break the seals on it? Is there a way to fix it? Thanks
Sep 20, 2007 at 1:59 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0e891de9c2="tsredsox"]I accidentally removed the fuel rail and it is now leaking gas. It is a 2002 Maxima with about 50000 miles and has a V6 in it. The car won't start and spit gas out of the valves on the fuel rail. Did I break the seals on it? Is there a way to fix it? Thanks[/quote:0e891de9c2]
pull the rail out check the o rings
Sep 20, 2007 at 2:05 PM
Suggested Repair
Remove the fuel rail and inspect the O-rings; replace any damaged seals before reinstalling the rail.
Conversation Summary
The owner of a 2002 Nissan Maxima accidentally removed the fuel rail. Fuel now leaks, the engine will not start, and gas sprays from the rail valves. The owner asked whether the seals were damaged and how to fix it. The expert advised pulling the rail and checking the O-rings.
