2000 Nissan Maxima ignition coils
2000 NISSAN MAXIMA
115,000 MILES • 6 CYL • FWD • AUTOMATIC
BBCAZES
Have a 2000 maxima. Rough idle and jerking start up. Changed out #2, 4, 6, 3 ignition coils, MAF sensor, starter, spark plugs. Now a month later, got the code to change out #2 & 4 ignition coils. What could be causing the ignition coils of go out. Any suggestions on what other problems.
Apr 8, 2008 at 2:23 AM
RACI47
  • 85 POSTS
remove the fuse to the fuel pump turn motor over and then pull all 6 plugs and see and smell what they look and smell like . . . if two are buried in fuel then injectors may be the cause also you can benchtest the coils themselves with a multimeter and a good haynes manual specific to the vehicle
Apr 8, 2008 at 3:45 PM
