2000 Nissan Maxima Brake Light will not go off
2000 NISSAN MAXIMA
HUGHEY999
The right rear brake caliper was leaking brake fluid. I replace the brake caliper and bled all of the brake lines. The brakes seem to work fine but the brake light will not go out. The brake fluid resivoir is full. I disconnected the battery for about five minutes to reset it but still comes on. Does anyone have any ideas?
Apr 10, 2007 at 10:56 AM
  • CAR REPAIR CONTRIBUTOR
[quote:26869704c7="hughey999"]The right rear brake caliper was leaking brake fluid. I replace the brake caliper and bled all of the brake lines. The brakes seem to work fine but the brake light will not go out. The brake fluid resivoir is full. I disconnected the battery for about five minutes to reset it but still comes on. Does anyone have any ideas?[/quote:26869704c7]
Try rebleeding it start from the M/C and then to the farthest to nearest.-that don't work-check the parking brake switch adjustment
Apr 10, 2007 at 11:29 AM
