1997 Nissan Maxima no spark
200,000 MILES • 6 CYL • FWD • AUTOMATIC
SHOHEL
engine runs good when it starts, after you drive for a bit or heat up the engine to normal temp. then it shuts off and when i try to start it dosen't and there is no spark. after cool down the engine it start again. can you plase tell me what to do? thank you
Dec 8, 2009 at 2:34 PM
PEAR69
  • 1,482 POSTS
How do you know there is no spark?
Have the ignition control module tested.
Dec 8, 2009 at 4:37 PM
SHOHEL
[quote:ed37fdbae5="pear69"]How do you know there is no spark?
Have the ignition control module tested.[/quote:ed37fdbae5]
yes i test with spark tester.
plase tell me what i should do next.
thank you
Dec 9, 2009 at 2:14 AM
PEAR69
  • 1,482 POSTS
Have the ignition control unit tested. If your car has an ignition ballast, have that tested also. Autozone or a place like that will test it for free.
Dec 9, 2009 at 10:19 AM
SHOHEL
i change ECU
Dec 9, 2009 at 1:56 PM
