1995 Nissan Maxima No Spark
1995 NISSAN MAXIMA
OLEGC
Engine Performance problem
1995 Nissan Maxima 6 cyl Front Wheel Drive Automatic 250.00 miles
At first I replaced the transmission. However, for two days it was very hard to start the engine, but it was possible. Now I am not able to start the car at all because there is no spark.The fuse is good and I replaced the ignition switch and the crank (REF and POS). I also checked the connectors and the wiring harness and everything works fine. The enjector impulse is good, but the spark does not work. I am wondering what could be wrong. Could there be a problem with the computer?
Thank you for your help.
May 25, 2010 at 3:55 PM
DOCFIXIT
  • 18,828 POSTS
Is there 12V + to red wire at coils key on?
May 26, 2010 at 3:24 AM
OLEGC
Yes, the crank sensor has a positive battery voltage.
May 26, 2010 at 7:19 AM
DOCFIXIT
  • 18,828 POSTS
Need to know if voltage at red wire to coils not crank sensor
May 27, 2010 at 4:55 AM
OLEGC
Yes, there is 12V + to red wire at coils.
May 27, 2010 at 5:25 AM
DOCFIXIT
  • 18,828 POSTS
With test light on red wire crank engine does light flash?
May 27, 2010 at 5:37 AM
OLEGC
Voltage that comes from the crank sensor is unpredictable. It ranges from 7 to 11 volts. I changed the crank sensor three times and there is still a problem.
May 27, 2010 at 5:52 AM
