1997 Nissan Maxima 6 cyl Front Wheel Drive Automatic
NO PRESSURE IN THE CLUTCH I CHANGE THE MASTER SLAVE CYLINDER AND THE SLAVE CYLINDER AND BLEED IT AND STILL NOTHING
Friday, May 28th, 2010 AT 10:54 PM
MECHANIC
HI there,
you may need to power bleed the system, did you bench bleed the master cyl? This is a very basic hydraulic system, do you get good flow when you bleed the system?
