You can do a comp test your self if you have the equipment, you will need a tester, and hand tools to remove the spark plugs, test one at a time and use full throttle when testing, have all plugs out and remove the fuel pump relay. The cam is just part of the system, if the tensioner has failed and cam timing is affected the chances of internal damage is possible, every thing can still turn and there can still be a problem with valve timing, if the timing is out enough, pistons will hit valves and bend them, this will result in low compression readings.
Mark (mhpautos)
SPONSORED LINKS
Saturday, May 29th, 2010 AT 7:58 PM
