1996 Nissan Maxima
JENNJOHS2424
  • 1996 NISSAN MAXIMA
Electrical problem
1996 Nissan Maxima 6 cyl Automatic
i have trouble codes P1445 and P0325 what are they and how do I go about fixing them? My brake lights wont work but the word brake is in my dash along with the battery light and check engine light.
Monday, January 18th, 2010 AT 12:54 AM
GLORENC
I have the same two codes, P0325 and P1445, on my 1996 Maxima. No problem with brake lights or idiot lights on the dashboard, though.
From the Haynes repair manual, P0325 is a "knock sensor or circuit fault". Try "Maxima knock sensor" on eBay for a visual, and then look under the intake manifold from the driver's side. Follow the cable back to the disconnect to the right of the intake manifold. Unplug there and test resistance between the two pins. No continuity means the sensor is bad (like mine is). Standard procedure says to remove the upper and lower intake manifolds, which is very painful. Some folks found an easier way -- see
https://www.2carpros.com/makes/nissan/maxima
The P1445 is the "EVAP canister purge volume control valve or circuit fault". This valve is easy to find, on top just behind the intake manifold. Unplug and test the resistances; see under "DTC P0440", starting with step 2. Electrically, mine is OK, but I need to dig deeper.
I'll post later once I know more. Anyone else out there with experience on these?
Tuesday, February 9th, 2010 AT 4:49 PM
