1995 Nissan Maxima Heat From Rear Seat
1995 NISSAN MAXIMA
250,000 MILES • 6 CYL • FWD • AUTOMATIC
MRSTHOMBLAN
  • 6 POSTS
I was sitting in the backseat of my car and I noticed heat coming from underneath the seat. The seat itself was warm to the touch and heat was coming out of the holes where the seat belt latches are attached. Where is the heat coming from? And how can the problem be fixed?
Mar 10, 2009 at 10:20 AM
JAMES W.
  • 2,394 POSTS
When you felt the heat around the seat, was the vehicle moving, or sitting still? My first thought is you may be missing an exhaust heat shield underneath the car. Please advise.
Mar 10, 2009 at 10:46 AM
MRSTHOMBLAN
  • 6 POSTS
The car was moving when I felt the heat.
Mar 10, 2009 at 11:40 AM
JAMES W.
  • 2,394 POSTS
Well, unless you have a rear seat heater, which I doubt, it has to be conducted heat from the exhaust or the engine being sucked in through the trunk. When this condition exists, close all the windows and turn the blower on high. See if the airflow stops. If it does, that should prove my theory.
Mar 10, 2009 at 12:27 PM
MRSTHOMBLAN
  • 6 POSTS
There are several components to the exhaust heat shield. Would you suggest I replace all of them?
Mar 10, 2009 at 12:35 PM
JAMES W.
  • 2,394 POSTS
If your asking my opinion, and if you actually have any heat shields missing, AND, if it's an issue that makes you uncomfortable, then you may want to have it looked at. Some of the missing shields may have been welded directly to the exhaust system itself. Replacing these could be a little "spendy". Choice is yours, please let me know how it comes out.
Mar 10, 2009 at 1:03 PM
MRSTHOMBLAN
  • 6 POSTS
Thanks for your help!
Mar 11, 2009 at 2:29 AM
JAMES W.
  • 2,394 POSTS
Your welcome, that's what we're here for. Just one question, does your Maxima really have 250,000 on it. If it does, that's really amazing. That says a lot about good maintenance.
Mar 11, 2009 at 5:42 AM
