Automatic Reclining Seats
NISSAN MAXIMA
CHUDROK
2000 Nissan Maxima- I have automatic reclining seats on the drver side and it no longer works. The Foward and Backward is working but the reclining up and down is not. I'm thinking its a problem with the wiring. Is there any way I can fix this myself with a manual or do I have to bring it into the shop?
Feb 24, 2007 at 9:24 AM
KNIGHTRIDERKITT2000
  • 93 POSTS
can you hear the seat motor when you push the switch, if so a cable might have broken,of not you should be able to unplug the motor from under the seat, and test the wiring to see if the switch even works
Feb 26, 2007 at 5:45 AM
