1993 Nissan Maxima I cant shift my car
148,000 MILES • 6 CYL • FWD • MANUAL
ADAMBROWN1234
I drove my Maxima through high water and the clutch didnt feel the same when I was driving home. The next day I got into my car, it started but I couldnt get it into gear. I replaced the slave cylinder a few weeks ago and this time I tried bleeding the line but that didnt work.
Jul 8, 2008 at 4:12 PM
KHLOW2008
  • 41,814 POSTS
Hi AdamBrown1234,
Are there any pressure felt when depressing the clutch pedal? Get some one to watch the slave cylinder push rod while depressing the clutch pedal, does it travel far?
If yes to both above, engage first gear, depress clutch, start engine. Remember to apply both brakes and handbrakes while doing this.
If car does not move forward, free gear and try engaging again, release clutch and depress before doing it.
Jul 8, 2008 at 10:05 PM
ADAMBROWN1234
Thank you so much. cause i did what you told me and it made a loud noise i thought i messed somthing up, but after it made that noise it went right in to gear. thank you again you saved me a lot of money cause some one told me it was the clutch. Thank you again.
Jul 9, 2008 at 4:57 AM
KHLOW2008
  • 41,814 POSTS
hi AdamBrown1234,
You are welcomed.
It was the clutch, got stuck to the flywheel when it got wet.
I suspected so and sorry I forgot to warn you about the noise that it would cause while releasing from the stuck position.
Jul 9, 2008 at 5:57 AM
