1992 Nissan Maxima
NEWPORT38
  • 1992 NISSAN MAXIMA
Engine Mechanical problem
1992 Nissan Maxima 6 cyl Front Wheel Drive Automatic
the car will not run with out me putting gas in the pvc val also when I leave the car will not take the gas so I can go
Thursday, March 18th, 2010 AT 4:16 AM
Check the fuel pressure and test the throttle position sensor and aiflow mter
Thursday, March 18th, 2010 AT 5:55 AM
NEWPORT38
Saturday, March 20th, 2010 AT 3:03 PM
NEWPORT38
The car still will not crank I put a new fuel pump, distrubor, mass flow sensor and throttle sensor
Saturday, March 20th, 2010 AT 3:12 PM
Check the injectors if they're pulsing while cranking the engine over better yet use a noid lite on the injector harness should be flashing if not and there's power to it and not flashing there's a problem with the computer injector ground drivers. Or a missing ignition reference input signal.
Saturday, March 20th, 2010 AT 5:28 PM
