1989 Nissan Maxima
2KC4U
  • 1989 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 145,000 MILES
I think I have a shortage in my fuel injector wires where would I get a new harness or should I just locate new wires and tap into the harness? How do I know I have bad injectors, when I got the car it had allot of power in it now its dragging. I got an air intake, NGK plugz and wires wat else do I need to give me more power.
Monday, March 17th, 2008 AT 1:37 AM
RACI47
  • 85 POSTS
Fuel injectors can be tested by putting a long screwdriver against one and the other end against your ear you should hear the audible clicking sound as they open and close with the engine running also have you changed the fuel filter recently?
Wednesday, April 9th, 2008 AT 1:13 PM
2KC4U
I just changed it last week! I think my timin chain may b bad. What r the symptoms of that? I caint really tell because of that shortage situation? Also I put a 3inch cone on my intake, and now its starting to dragg, I have already reset the ecu. What can I do next. I also have ngk wires and plugz.
Wednesday, April 9th, 2008 AT 4:09 PM
RACI47
  • 85 POSTS
Check the timing with a light as for the chain I have a 95 maxima and had to change it out it may be bad because the older models did not use the stainless steel
Thursday, April 10th, 2008 AT 3:33 AM
