1989 Nissan Hardbody High idle
299,000 MILES • 4 CYL • 2WD • MANUAL
ALLCEAYT
My okd truck is idling high and will not kick down after
warmed up. I have adjusted idle and does not help.
Should I replace the carb. or is this a common thing
that has some troubleshooting that can be done.
Thank you
Oct 28, 2010 at 9:27 AM
MMPRINCE4000
  • 8,548 POSTS
High idle can be caused by vacuum leak. Check all vacuum hoses for cracks, use carb cleaner and spray on suspected hoses, if idle changes, then that is bad hose.
Oct 28, 2010 at 11:11 PM
