1986 Nissan Hardbody hard starting and hi rpm
OOOBUCKMAN
Engine Performance problem
1986 Nissan Hardbody 4 cyl Two Wheel Drive Manual
engine hard to start motor turns and engine fires but shuts off immediately and around 2000 rpm engine acts as if running on 2 cylinders.recently replaced engine computor and alternator and fuel filter and fuel pressure regulator
is Z24i motor with dual plugs
Oct 13, 2010 at 11:27 AM
  • 75,988 POSTS
Napz-check and test the cold start injector and clean out the IACV, FICD and TPS sensor-
Oct 13, 2010 at 11:33 AM
