1998 Nissan Frontier Dies Over 2000 RPM
SLAYGAME1
1998 Nissan Frontier, when I disconnect my negative side of the battery, my engine will run fine; however when I go over about 2000 RPM's it cuts off. I had my alternator checked yesterday and it was working even when a load was applied.
Jan 18, 2007 at 8:07 AM
  • 75,988 POSTS
Never disconnect a cable while engine is in operation, you're asking for trouble.
Best scenario here, have the charging system tested for no load and load. You sounded like the regulator is not controlling the alty.
Also do an open voltage check on the battery. A good battery will read 12.4volts or better before starting. While running when loaded should read 13.2-14.5 and shall not exceed 16volts. Anything over 16v is overcharging killing the battery and also the regulator is not up to par.
HTH-Good Luck
Jan 18, 2007 at 8:04 PM
Suggested Repair
Do not disconnect the battery while the engine is running. Have the charging system tested under no-load and load, and check battery open-circuit voltage (about 12.4V or higher before starting; 13.2-14.5V while running under load, never over 16V). Suspect the voltage regulator is not controlling the alternator.
Conversation Summary
A 1998 Nissan Frontier runs with the negative battery cable disconnected but cuts out above about 2000 RPM. The alternator had already been checked and worked under load. The expert warned against disconnecting a battery cable with the engine running and recommended no-load and load charging-system tests plus a battery voltage check, noting the regulator may not be controlling the alternator and that voltage over 16V indicates overcharging.
