Cranks but will not start
110,000 MILES
PATTI MAY LANIER
I replaced the fuel pump and filter. it cranks and started when I used starting fluid but will not keep running.
Sep 4, 2019 at 11:48 AM
Let's start from the beginning. You confirmed that it is a fuel issue but we need to find out what the pressure is. If we just assume the pump is building pressure then we could waste a lot of time.
Here is a guide on how to test the fuel pressure:
Once we know the pump can build pressure, we can go to the next step.
Also, can you let me know what model and engine you have? Thanks
Sep 5, 2019 at 9:15 AM
