The light of "Engine serving soon" is on on the front panel. Went to Autozone and asked for check
the problem. The detail content as following:
Troubleshooting P0304
Definition:
Cylinder misfire detected-Cylinder number 4
Explanation:
The powertrain control module monitors the crankshaft speed and has detected a misfire condition
Probable causes:
1. Ignition system fault-spark plug(s), ignition wires,
2. Vacuum leak,
3. Injector fault,
4. High or low fuel pressure.
The light has been on for months. When I wait for on the red light and pedal the break, I feel the
car trying to push out although I break it and it is viberating more than before.
Is it a big problem? If I try to fix it by myself, is there a probability and what is the
procedure? Thank you!
Ganou
SPONSORED LINKS
Tuesday, May 1st, 2007 AT 1:04 PM
