1997 Nissan Altima Stalls After Driving
JAMCUSH
  • 7 POSTS
Hello Bob and Ken and thanks in advance for you assistance. I have a 1997 2.4L Nissan Altima GXE. The problem is when I first start the engine the car drives good however after about 20 min. of driving I lose power and the car stalls out. During this time I can not exceed 3000 rpms or the car will stall and begin to sputter and vibrate. It also only will increase speed if I continue to gradually add gas and not exceed the RPMs. I have checked the lines and all hoses. I also checked the fuses. I tried to get a reading from the car but the code reader could not get anything. The service soon light is still on also. This problem just began about 4 days ago. If you could help me please do.
Apr 5, 2007 at 11:41 AM
  • 75,988 POSTS
Have the fuel system check that clears out-we'll go to other areas
Apr 5, 2007 at 4:48 PM
JAMCUSH
  • 7 POSTS
I have changed the fuel filter and checked the entire lines. I also had the injectors cleaned. I am wondering could it be the coils or the module that is giving me the problem since the vehicle starts acting this way when it runs for a while?
Apr 7, 2007 at 9:17 AM
  • 75,988 POSTS
[quote:34ad698c63="jamcush"]I have changed the fuel filter and checked the entire lines. I also had the injectors cleaned. I am wondering could it be the coils or the module that is giving me the problem since the vehicle starts acting this way when it runs for a while?[/quote:34ad698c63]
When it dies out-immediately check for spark and fuel one of this is gonna be missing in action.
Comeback and tell me what's missing we'll go from there.
Apr 7, 2007 at 9:56 AM
JAMCUSH
  • 7 POSTS
Now I do know how to check for fuel but i haven't a clue on how to check for spark. silly huh. At any rate can ya give me some direction?
Apr 7, 2007 at 10:34 AM
  • 75,988 POSTS
[quote:8fba6e8455="jamcush"]Now I do know how to check for fuel but i haven't a clue on how to check for spark. silly huh. At any rate can ya give me some direction?[/quote:8fba6e8455]
Remove a plug wire stick a screwdriver in it and ground it to the engine or good ground point crank it over it should be producing spark and comeback
Apr 7, 2007 at 11:23 AM
JAMCUSH
  • 7 POSTS
I did exactly what you said and it sparked. what is next
Apr 7, 2007 at 11:57 AM
JAMCUSH
  • 7 POSTS
I did notice that when it died out it sounded as if it was not getting enough fuel
Apr 7, 2007 at 12:04 PM
  • 75,988 POSTS
[quote:25946a41ab="jamcush"]I did notice that when it died out it sounded as if it was not getting enough fuel[/quote:25946a41ab]
Was it running fine but quit suddenly? The most likely causes here would be a failed fuel pump, ignition module or broken overhead cam timing belt.
Try cranking it over while someone be listening to the injectors, it suppose to be clicking/buzzing and comeback
Apr 7, 2007 at 10:52 PM
JAMCUSH
  • 7 POSTS
I think I have found the problem. I started the vehicle up and everything went fine until i touched the mass air flow sensor. When i bumped into it the engine stalled again and cut off. So I started it up again and pushed down on the sensor and sure enough the vehicle stalled again and cut off. Have you ever heard of this happening before?
Apr 9, 2007 at 12:36 PM
  • 75,988 POSTS
[quote:a30ff126e6="jamcush"]I think I have found the problem. I started the vehicle up and everything went fine until i touched the mass air flow sensor. When i bumped into it the engine stalled again and cut off. So I started it up again and pushed down on the sensor and sure enough the vehicle stalled again and cut off. Have you ever heard of this happening before?[/quote:a30ff126e6]
Open it up and investigate what's happening in there check the flaps/ pins and test it out by the book specs.bumping on it shouldn't do that-just imagine if you're going down a bumpy road-you think its suppose to do that and get back
Apr 9, 2007 at 1:23 PM
Suggested Repair
Inspect the mass airflow sensor, including its flaps and pins, and test it to factory specifications. Touching the sensor should not stall the engine; repair or replace it if it fails testing.
Conversation Summary
A 1997 Nissan Altima 2.4L ran normally at first but lost power, sputtered, and stalled after about 20 minutes, especially above 3000 RPM. The service light was on and a code reader found nothing. Fuel filter, lines, and injectors were already serviced, and spark was present when checked. The owner then found that bumping or pressing the mass airflow sensor stalled the engine. The expert advised opening the sensor, inspecting the flaps and pins, and testing it to specifications.
