2001 Nissan Altima Rough Idle
JHR2211
I have a Nissan Altima 2001 Special Edition, approx. 72,000 miles. Today the car started idling rough, almost coming to a stop. When the a/c is started, the car idles better. Not sure what is going on.
Thanks,
jhr2211
Jan 3, 2007 at 11:31 AM
  • 75,988 POSTS
Have the computer scan for OBD2 codes.
Jan 3, 2007 at 1:47 PM
JHR2211
[quote:f41444700c="rasmataz"]Have the computer scan for OBD2 codes.[/quote:f41444700c]
I don't have a scanner to use to scan for codes.
Jan 3, 2007 at 2:07 PM
  • 75,988 POSTS
No scanner or code reader-buy a chilton book for it and check the following: idle speed control valve, throttle position sensor, throttle position switch.
BTW is the CEL/MIL/SES etc On-while idling
When did it last seen a major tune-up
Jan 3, 2007 at 5:57 PM
Suggested Repair
Scan for OBD-II codes. If a scanner is unavailable, use a repair manual to inspect the idle speed control valve, throttle position sensor, and throttle position switch. Also note whether the check engine light is on and when the last major tune-up was performed.
Conversation Summary
The owner of a 2001 Nissan Altima with about 72,000 miles reports a rough idle that nearly stalls, though idle improves when the air conditioning is on. The expert recommends scanning for OBD-II codes and, without a scanner, checking the idle speed control valve, throttle position sensor, and throttle position switch, while also asking about the check engine light and last tune-up.
