2003 Nissan Altima Stalls at Stop
SOULJAHSLIM305
i have a 2003 nissan altima with a 2.5s engine automatic trans. with 94,000 miles. when i turn my engine on in the morning it does it fine, when i put my car in drive it jumps on me as if though it wants to turn off on me. when im driving down the road from time to time if feels like my car wants to turn off on me and it does sometimes but only when im coming to a stop. i changed my upstream oxygen sensor but not my downstream sensor i did a scan on it n it shows that my downstream is running lean, can this be the cause of my problem or can i be having another one, i had a trouble code p0420. i believe the the problem is with the oxygen sensor. by me letting the car run in this way can i damage the cat. converter. thank u 4 ur help.
May 30, 2007 at 1:58 PM
2CARPRO JACK
  • 11,533 POSTS
has it ever been tuned up? 0420 is usually a cat efficiency code, the converter may be bad if the sensor has already been changed (downstream)
May 31, 2007 at 1:06 AM
SOULJAHSLIM305
i have only changed the spark plugs, done oil changes every 3 thousand miles, changed the trans. fluid. and changed the upstream oxygen sensor. do u think that its time for me to do a valve adjustment.
May 31, 2007 at 10:15 AM
2CARPRO JACK
  • 11,533 POSTS
Try cleaning the throttle bore with carb spray and a rag.Might also want to try a downstream o2 sensor
May 31, 2007 at 10:42 AM
Suggested Repair
Clean the throttle bore with carburetor cleaner and a rag, and try a downstream oxygen sensor. P0420 is typically a catalytic converter efficiency code, so the converter may still be faulty if the downstream sensor does not resolve it.
Conversation Summary
A 2003 Nissan Altima 2.5S with 94,000 miles jumps or nearly stalls when shifted into drive and sometimes stalls when coming to a stop. The owner replaced the upstream oxygen sensor and spark plugs, saw a lean downstream reading and code P0420, and asked whether the sensor, a valve adjustment, or catalytic converter damage was involved. The expert said P0420 usually indicates converter efficiency, recommended cleaning the throttle bore, and suggested trying a downstream oxygen sensor.
