Nissan Altima Long Crank and Bogging
Suggested Repair
After fuel, spark, compression, vacuum, and MAF checks, inspect ignition timing and the cam lobes. Unmetered air and an early-opening EGR were also suggested; unplugging the MAF made the engine die, so the MAF was not confirmed as the cause. The owner later said the problem was fixed but did not identify the repair.
Conversation Summary
A Nissan Altima needed long cranking to start, then bogged and sometimes died under throttle. The owner had already checked the fuel filter, pump, pressure, plugs, distributor, injectors, MAF, compression, vacuum, wiring, and codes. An expert suggested checking the intake plenum for unmetered air, testing with the MAF unplugged, and considering an EGR opening too early. After a loud intake pop and white smoke, the expert suspected incorrect timing or a worn cam lobe. The owner reported the problem fixed without stating the exact repair.
