1993 Nissan Altima No Start Weak Coil
R8DERGRL1
  • 7 POSTS
does anyone know how which type of coil my car has there are two types #1 HAP OR #2 HANSHIN any info would be greatly appreciated. MY car is a 93 altimaSE 2.4 4cyl w/200,000 miles
Apr 25, 2007 at 11:45 AM
  • 75,988 POSTS
What's wrong with the old one-No spark!
Apr 25, 2007 at 12:07 PM
R8DERGRL1
  • 7 POSTS
car just stopped running and won't start again,have already replaced fuel pump and distributer,tested ignition module so we figure its all thats left
Apr 25, 2007 at 12:11 PM
  • 75,988 POSTS
Why don't you bench test the coil's primary and secondary resistances before you condemn it-Hows the timing belt is it still there? Do you have power to the coil.
Apr 25, 2007 at 12:56 PM
R8DERGRL1
  • 7 POSTS
timing belt seems fine cuz the car will run for a few minutes then shut off, not sure how to use the ohm meter to check coil i don't have the digital kind just the old type meter,did the spark plug test and the spark is yellow not blue.
Apr 25, 2007 at 2:05 PM
  • 75,988 POSTS
[quote:96c3008a02="r8dergrl1"]timing belt seems fine cuz the car will run for a few minutes then shut off, not sure how to use the ohm meter to check coil i don't have the digital kind just the old type meter,did the spark plug test and the spark is yellow not blue.[/quote:96c3008a02]
Yellow is a sign of a weak coil
Apr 25, 2007 at 6:45 PM
R8DERGRL1
  • 7 POSTS
i tested the coil with a digital ohm meter and got all 0's then i tested the coil and the distributer also all 0's should have been 1ohm for the coil and at least 10 kilohms for the coil/dist reading any other ideas?
Apr 26, 2007 at 12:09 PM
  • 75,988 POSTS
The secondary windings is kind of low -try coil substitution-further check the crank angle sensor this is the one that tells the computer to fire the coil to get the secondary kilovolts to the plugs.
If you feel that the ignition system is working accordingly. Try checking the timing belt, fuse for the ignition and main relay.
Check all the connections on the coil and distributor and the computer box and its ground.
Apr 26, 2007 at 1:38 PM
Suggested Repair
Yellow spark and zero-ohm coil readings indicate a weak or open ignition coil, so substitute the coil. Also check the crank angle sensor, timing belt, ignition fuse, main relay, and connections and grounds at the coil, distributor, and computer.
Conversation Summary
A 1993 Nissan Altima SE 2.4 stopped running and would not restart after the fuel pump and distributor were replaced and the ignition module was tested. The owner asked whether the coil was HAP or Hanshin and reported yellow spark plus zero-ohm coil readings. The expert said yellow spark indicates a weak coil, recommended coil substitution, and advised checking the crank angle sensor, timing belt, ignition fuse, main relay, and related connections and grounds.
