1998 Nissan Altima AC Water on Floor
BABYEBK
  • 6 POSTS
i have a 98 nissan altima with 170000 miles and for some reason i found alot of water on my floor on both the driver and passenger side but mostly on the passenger side i checked for visible leaks especially when it rains and i found none but i noticed that the leak started when i use the air conditioner i wonder if that has to do with the water on the floor thank u for ur time
Jun 10, 2007 at 11:28 AM
  • 75,988 POSTS
[quote:16037bfec9="babyebk"]i have a 98 nissan altima with 170000 miles and for some reason i found alot of water on my floor on both the driver and passenger side but mostly on the passenger side i checked for visible leaks especially when it rains and i found none but i noticed that the leak started when i use the air conditioner i wonder if that has to do with the water on the floor thank u for ur time[/quote:16037bfec9]
The drip drip drip is normal
Jun 10, 2007 at 11:31 AM
BABYEBK
  • 6 POSTS
i know the drip is nornal but there was alot of water inside my car on my floor if u step on the carpet water will ooze out thats alot to water for a drip i have a feeling that maybe water isnt draining out i would like ur opinion thank u
Jun 10, 2007 at 11:38 AM
  • 75,988 POSTS
[quote:87c9450bfc="babyebk"]i know the drip is nornal but there was alot of water inside my car on my floor if u step on the carpet water will ooze out thats alot to water for a drip i have a feeling that maybe water isnt draining out i would like ur opinion thank u[/quote:87c9450bfc]
Could be the drain tube clogged-up or the heater core is leaking
Jun 10, 2007 at 4:41 PM
Suggested Repair
Check whether the A/C evaporator drain tube is clogged and clear it so condensate drains outside. Also inspect the heater core for a leak, which can put water on the floor.
Conversation Summary
The owner of a 1998 Nissan Altima with 170,000 miles found a large amount of water on the driver and passenger floor, mostly on the passenger side. No rain leak was visible, and the water appeared when the air conditioner was used. The expert said normal A/C dripping is expected, but this much interior water could mean a clogged drain tube or a leaking heater core.
