1993 Nissan Altima Poor Acceleration
ELVISNISE
93 altima gxe, auto 194k. Extremely poor acceleration in 1st gear(have to floor it to get to 2nd), gets progressively better thru each gear. This problem is intermittent but lately a white smoke will come from underneath car when this happens, no odor. Has new fuel/air filter, spark plugs/wires. Is it the cap/rotor, mass airflow sensor or o2 sensor? The valve cover also has a prominent oil leak(needs 1 bottle a week to stay level).
Jul 30, 2007 at 9:19 PM
  • 75,988 POSTS
[quote:16369bc6eb="elvisnise"]93 altima gxe, auto 194k. Extremely poor acceleration in 1st gear(have to floor it to get to 2nd), gets progressively better thru each gear. This problem is intermittent but lately a white smoke will come from underneath car when this happens, no odor. Has new fuel/air filter, spark plugs/wires. Is it the cap/rotor, mass airflow sensor or o2 sensor? The valve cover also has a prominent oil leak(needs 1 bottle a week to stay level).[/quote:16369bc6eb]
You should have change the cap/rotor.Possibilities: TPS/MAF/VSS/and my favorite CTS sensors
Make sure you have a tight connection from the s/plug to the cap.
Oil leak try tightening it up.
Jul 30, 2007 at 9:32 PM
Suggested Repair
Replace the distributor cap and rotor and confirm a tight spark-plug-to-cap connection. Also check the TPS, MAF, VSS, and CTS sensors. For the valve-cover oil leak, try tightening the cover.
Conversation Summary
A 1993 Nissan Altima with an automatic and high mileage has intermittent, very poor acceleration that is worst in first gear and improves in higher gears, with odorless white smoke from underneath when it happens. Fuel and air filters, plugs, and wires are new, and the valve cover leaks about a bottle of oil a week. The expert recommends replacing the cap and rotor, ensuring a tight plug-to-cap connection, checking the TPS, MAF, VSS, and CTS sensors, and tightening the valve cover.
