Replacing BCM
38,000 MILES • 4 CYL • FWD • AUTOMATIC
TULA
The turn signals are intermittent...sometimes one works, but usually neither work. After 8 days at the dealer, they said the BCM was bad. I chose to repair/replace it myself to save approx $500. I found a used one online (exact P/N) and replaced the module (battery disconnected), but the car would not start with the new module. It would turn over, but not start....blinkers weren't working either. Is there a 'reset' method that must be done to get the new BCM working properly, or is the BCM I bought no good?
Any assistance would be greatly appreciated.
Oct 18, 2008 at 12:43 AM
MERLIN2021
  • 17,250 POSTS
The BCM must be initialized most shop will do this for about $130.00 or you got a bad BCM. . Please let us know if you need anything else to get the problem fixed.
Cheers
Oct 18, 2008 at 12:50 AM
