2003 Nissan Altima RPM- please help!
LULUBUG1984
  • 2003 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • 81,000 MILES
I have a '03 nissan altima. I have had it checked for the second time a couple of wks ago and got a diagnostic test done again b/c the check engine light was on. Nothing came up and they turned the light off. Two miles later the light was on again. When I got my car inspected, it failed b/c it was idling at 2400 rpm. Do you think this is a leak or I need a new valve if it isn't detectable?
Monday, January 21st, 2008 AT 10:35 PM
LOSTINMARS
  • 222 POSTS
The vehicle has lost its idle parameters. Now a simple reset, with the proper software/scan tool, might fix it or the throttle body itself might be bad. Either way you need to find someone with the proper equipment to repair this.
Wednesday, January 23rd, 2008 AT 11:10 PM
