2002 Nissan Altima POO21 ERROR
KROBERTS57
  • 2002 NISSAN ALTIMA
Engine Mechanical problem
2002 Nissan Altima 6 cyl Two Wheel Drive 143800 miles
Hi, my car won't start, it makes a grinding noise, not turning over at all. My brother used his OBD2 and we get the P0021 error.
Tuesday, November 2nd, 2010 AT 2:41 PM
  • 109,755 POSTS
The code is regarding the intake valve timing (IVT). Usually a bad IVT sensor or cam sensor. I have to ask, when you try to start it and you hear a grinding, is the engine turning?
Tuesday, November 2nd, 2010 AT 8:44 PM
KROBERTS57
The very first time I started the car it did try to turn over, but every time after it just made the grinding sound. My brother told me to try to start it today -I hadn't tried since Sunday and it started just fine.
Tuesday, November 2nd, 2010 AT 9:08 PM
  • 109,755 POSTS
I think you may be dealing with two problems. The grinding when you turn the key to start sounds like a bad solenoid on the starter not fully engaging with the flywheel. When that happens, the gears grind. Does that sound like what you heard?
As far as the other problem, is the light still on?
Tuesday, November 2nd, 2010 AT 9:31 PM
KROBERTS57
Yes it is a grinding noise and yes, the check engine light was still on.
Tuesday, November 2nd, 2010 AT 11:26 PM
  • 109,755 POSTS
If the starter continues to do that, remove it and have it bench tested. It sounds like the solenoid is going bad. As for the other issue, something tells me the cam sensor is going bad. If the light is still on with the same code, that is my first guess.
Wednesday, November 3rd, 2010 AT 7:34 AM
KROBERTS57
Thank you for your help. Hopefully my brother can fix it.
Wednesday, November 3rd, 2010 AT 12:44 PM
  • 109,755 POSTS
You're welcome. I just hope that is the problem. From experience and some research, that it what I am seeing.
Let me know if you have other questions, and thanks for using 2carpros. Com.
Wednesday, November 3rd, 2010 AT 1:45 PM
