I am experiencing difficulty in steering, particularly when turning corners. The steering wheel feels very tight and makes it hard to turn corners. At times, upon difficulty turning a corner the power steering will seem to kick back in and cause some jerking when turning. I checked the power steering fluid and it is full. I followed the lines from the p/s pump as far as I could and did not see any leaking. I am hoping a bad cylinder on the rack and pinion assembly isn't the cause. Any troubleshooting suggestions? Thank you.
Mar 3, 2008 at 11:43 AM
