2002 Nissan Altima
ABUMAZIN
  • 2002 NISSAN ALTIMA
2002 Nissan Altima 4 cyl All Wheel Drive Automatic
MY CAR BURNS OIL 10 DAYS OIL IS GONE PLESAE TELL ME WHAT THE PROBLEM
Monday, November 23rd, 2009 AT 4:05 PM
  • 31,937 POSTS
Hi there,
You may well have a ring problem causing oil to enter the combustion chamber and be burnt, also if you are using a synth oil and the engine is worn this will also cause oil consumption problems, have a comp test done to check lower end readings, and if these are reasonable use a mineral oil this will not fix the problem but it may slow it down, if the lower end is worn you will need a re ring or full over haul or a change over engine.
Mark (mhpautos)
Monday, November 23rd, 2009 AT 4:20 PM
