EGR Valve
2CARPRO JACK
  • 11,533 POSTS
The EGR passages could be plugged with carbon. Manually pull on the EGR valve at idle, car should come very close to stalling, if not actually stalling. If littel or no change is seen then the passages must be cleaned out.
Wednesday, November 13th, 2019 AT 12:43 PM (Merged)
DIANEMARIE
  • 5 POSTS
I did test the egr valvle at idle and engine stalled. I am starting to think I have a defective catalytic converter even though its two years old. I even put in BlueSky (6oz) twice ran the gas down to practically empty followed all the directions and still failed (the readings did come down a bit from 3.23 to 2.89 and the limiit is 250 this is why I and now thinking the converter is somehow defective. Have you ever heard of such a problem with a converter?
2CARPRO JACK
  • 11,533 POSTS
Yes, but it isnt real common. If you have a vacuum tester, hook a long piece of vacuum line to it and use the tester in place of the EGR valve and drive it with the tester where you can see it. This will tell you if the system that controls it is applying vacuum to the valve when driving
DIANEMARIE
  • 5 POSTS
I performed the test you suggested, by teeing in a vaccum gauge between the bpt and the egr valve. I am getting 3 inches of vaccum at the egr valve on accelleration with the rpm at 2000 to 2500 rmps. When I deaccelerate the vaccum falls off and turns back on when I accelerate. I would like to know if I should take a chance and retest, this would be my fourth time at $29.00 a pop. I am still leary of the converter. I ran this test for 26 miles and it was consistant. I also contacted the manufacturer of the converter and explained the problem. He concurred with me that is possible that the converter could be bad and is covered under warranty. What do you think should I get the new converter then retest?
2CARPRO JACK
  • 11,533 POSTS
If it is free, go for it. Not sure 3 inches of vacuum is enough to activate the egr valve.
DIANEMARIE
  • 5 POSTS
Would the converter cause me to get low vaccum as you suggest? According to all the manuals (Haynes - Shop Manual for 1993 manual) they said 3 inches was enough what should it be - because I'm going for the converter and I going to try your test again.
TBROUSSARD
  • 2000 NISSAN ALTIMA
Computer problem
2000 Nissan Altima 4 cyl Front Wheel Drive Automatic
Where is the EGR valve located on a 2000 Altima? Engine check light is on?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_00altimaegr_1.jpg
MIL on. Give us the code numbers. Don't have them? Go to the nearest Autozone and have them scan the ECM.
TBROUSSARD
The code is P1400 per Autozone, EGRC solenoid Valve?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_00altimaegr_2.jpg
1. Disconnect the solenoid valve electrical harness and vacuum lines.
2. Air should pass between Ports A and B freely.
3. Apply battery voltage and ground to the solenoid terminals.
4. Air should NOT pass through Ports A and B freely.
5. Air should now pass through Ports A and C freely.
Discard the valve if it does not respond as indicated.
If the valve does responds as indicated then check for problems in the power and ground circuits to the valve.
BTW, this is a dealer part only.
TBROUSSARD
What do you use for air flow? Do this with the engine running? Use an external power source of 12Volts?
Please clarify/Thanks!
ZACKMAN
  • 4,202 POSTS
Use engine vacuum when the engine is running. You can use jumper wires from the fuse block, not from the battery directly.
