2001 Nissan Altima P0304 Misfire
FBORGESE
4cylinder 40,202 miles, Auto Trans,
PO304 misfire cylinder #4 detected
complete tune up was done sept. 2007
plugs, wires,air filter, gas filter, replaced fuel injecter
for cylinder #4,new rotor and distributor cap.
Engine light still on, service engine soon.
The distributor was not replaced is this the problem?
or is there a sensor that has to be replaced?
Oct 2, 2007 at 5:06 AM
SERVICE WRITER
  • 9,123 POSTS
Check for an intake manifold gasket leak. Around the # 4 cylinder intake gasket area, you can spray intake cleaner, wd-40, propane etc. and listen for an idle change. Another way is to use a smoke machine to spot it while it isn't running.
Oct 2, 2007 at 5:24 AM
Suggested Repair
Check for an intake manifold gasket leak around cylinder 4 by spraying intake cleaner, WD-40, or propane and listening for an idle change, or use a smoke machine with the engine off.
Conversation Summary
A 2001 Nissan Altima owner reports a persistent P0304 cylinder 4 misfire and service engine light after plugs, wires, filters, the cylinder 4 injector, rotor, and distributor cap were replaced. The expert recommends checking for an intake manifold gasket leak near cylinder 4.
