2003 Nissan Altima Stong fuel smell left rear wheel well
2003 NISSAN ALTIMA
RSTUCKEY
Smells problem
2003 Nissan Altima 4 cyl Automatic 52,000 miles
We have reciently noticed a fuel smell at the left rear wheel of the auto. The engine light does not come on. When you remove the gas cap you hear noise from the fuel cell. I have replaced the gas cap, raised the car and checked for leaks, found none.
Is there a way to inspect the soft link on top of the fuel cell without dropping the tank. I think the soft link may have a crack, or I may have a fuel pump problem.
One more symptom, the engine does not always start with the first attempt but always the second time.
Looking for help as I am not working and can't afford an expensive auto repair.
Randy Stuckey
Aug 31, 2010 at 8:30 AM
EDWARD.S
  • 166 POSTS
Hi,look At The Two Hoses Leading Into the fuel tank.Look Close for Cracks In The hoses.Also have the Fuel cap checked,that it holds pressure.I seen a few nissans with cracked fuel hoses at the tank.those hoses are dealer only parts.
Hope This Helps You,
Good Luck
Edward S.
Aug 31, 2010 at 12:29 PM
AB1975
  • 15 POSTS
the filler neck assembly could be rusted ....
Oct 12, 2010 at 8:46 AM
