I have the 2.4 engine. I need timing chain diagram or marks. Could you please show me a picture where the dowel pins in the right position for the chain to be applied? Thank you.
Wednesday, February 25th, 2009 AT 11:27 PM
KEN L
MASTER CERTIFIED MECHANIC
Hello, I have found both 4 and 6 cylinder timing chain diagrams for you just in case someone else wanted to see the other engine. Here are some I have others below:
Check the diagrams (BELOW)
Cheers, Ken
Images (Click to make bigger)
SPONSORED LINKS
Thursday, October 12th, 2017 AT 7:18 PM
MIKEDEROUIN88
MEMBER
1998 NISSAN ALTIMA
I need the torque specs and tightening sequence for head bolts and a timing chain diagram
Thursday, October 12th, 2017 AT 7:19 PM
(Merged)
KHLOW2008
MECHANIC
There you go.
(Merged)
CKITCHENS
MEMBER
1999 NISSAN ALTIMA
2.4L
4 CYL
2WD
144,000 MILES
Lower timing chain broke. Replaced entire timing kit and head gasket. Engine fires and shudders for a second then just turns and doesn't run. Ignition is firing fuel injectors should be fine and we double checked timing marks. Not sure what else could be wrong.
Thursday, October 12th, 2017 AT 7:20 PM
(Merged)
HMAC300
MECHANIC
If the chain broke while running it probably bent valves check compression it is an interference engine
SPONSORED LINKS
(Merged)
CKITCHENS
MEMBER
We checked compression and it varied between 60 and 90 in all cylinders
(Merged)
HMAC300
MECHANIC
Ya should be minimum 105 on each. You probably bent valves like I said it's an interference engine and if it was running when it broke you bent valves or if not and you turned cams or engine over they got bent.
(Merged)
CKITCHENS
MEMBER
That makes a little more sense. I don't really know this engine real well. Just trying to see if I could get it back running myself. If it is not too costly to replace valves I may just leave it to an expert. Thank you so much for taking your time to respond. Your info was very helpful.
(Merged)
KEN L
Hey CKITCHENS,
I don't mean to jump in here but it sounds like the timing of the chain could be off because of the uniform low compression, usually it will have one or two low cylinders if damage has occurred. Can you recheck the marks?
I found these diagrams for you, please let us know how it goes
(Merged)
ROBBS2541
MEMBER
1999 NISSAN ALTIMA
Engine Mechanical problem
1999 Nissan Altima 4 cyl Front Wheel Drive Automatic
need the timing marks to align the timing chain tha someone else took off
updated 11/30/09
the cam gears are not marked that way on this vehicle there are 2 lines on each gear
(Merged)
BLUELIGHTNIN6
MECHANIC
(Merged)
TOMAS1988
MEMBER
1 POST
2000 NISSAN ALTIMA
2.4L
4 CYL
FWD
AUTOMATIC
173,000 MILES
My timing component guides broke so I has to replace the oil pump because the chain ripped a hole in the pump cover and since the cover and pump are one assem. Just swapped it out along with new crankshaft idler and cam sprockets pensioners guides and chain. I lines up the timing chain marks with the sproket timeing marks. I have my plugs out. When I turn the motor with a ratchet from the crank bolt the motor turns clean. My question is should my timeing marks line up when the chain comes all the way around and it's back at tdc. Or do they only line up when u put it together the first time to set it a that's it?
SPONSORED LINKS
(Merged)
CARADIODOC
MECHANIC
The timing marks had better line up at every second crankshaft rotation. That is how the valves stay in correct timing relationship to the movement of the pistons.
