Hi there,
this will be the front crankshaft oil seal, it is behind that pulley, with the pulley removed the seal can be pryed out and a new seal inserted, just make sure that whoever dosed this makes sure that the seal surface on the harmonic balancer(front pulley) is not grooved as if it is, the new seal may start leaking again.
Mark (mhpautos)
SPONSORED LINKS
Monday, February 1st, 2010 AT 6:35 PM
