HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Nissan
Altima
Engine Cooling
Radiator
Replace/Remove
1998 Nissan Altima Radiator
SALAZAR3
MEMBER
1998 NISSAN ALTIMA
4 CYL
4WD
AUTOMATIC
12,600 MILES
How do you change the radiator
Thursday, July 23rd, 2009 AT 3:49 PM
STEVEW84
MECHANIC
Probably gonna have to take the fans out. Take both upper and lower radiator hoses off. Take the trans lines off. Take the radiator holddown off. Take whatever else you need to take off.
SPONSORED LINKS
Thursday, July 23rd, 2009 AT 8:55 PM
Please
login
or
register
to post a reply.
Related Radiator Replace/Remove Content
I Have A Crack In The Radiator Just Below The Fill Cap. It Is Plastic On This Top Part Of The Radiator. Is There A Repair For This, Or Is...
Asked by
coltjp
1 ANSWER
1998
NISSAN ALTIMA
VIDEO
Radiator Replacement Kia Sportage
Instructional repair video
GUIDE
A radiator removes heat from the engine through thermal heat exchange using coolant as a conductor and is usually located in the front of the vehicle under the hood. A ...
1998 Nissan Altima Radiator Is Losing Fluid
I Am Actually Writing For My Son. His Altima Is Losing Radiator Fluid Almost Daily. After Parking His Car At Night The Following Morning It...
Asked by
awillism L Bailey
1 ANSWER
1998
NISSAN ALTIMA
1999 Nissan Altima Radiator Leak
My Car Was Overheating And Leaking Antifreeze. The Repair Shop Has Indicated That The Radiator Neck Is Broken Because The Mounts Are Weak...
Asked by
linanlexy
1 ANSWER
1999
NISSAN ALTIMA
1996 Nissan Altima Hidden Radiator Problem Causes...
I Swerved To Miss A Deer In My Ka24de Altima And Took Out A Sign, But Drove It Home Fine. The Next Day (3 Days Ago), It Overheated After...
Asked by
txrambler
1 ANSWER
1996
NISSAN ALTIMA
2009 Nissan Altima
I Have A 2009 Nissan Altima Thats Overheating. When Im On The Freeway At High Speeds It's Fine, But When Im At Lower Speeds The Temp Starts...
Asked by
gholman25
2009
NISSAN ALTIMA
VIEW MORE
SPONSORED LINKS
Radiator Hoses and Thermostat Replacement
Online car repair manuals
