1998 Nissan Altima Key Stuck in ignition wont turn to off p
1998 NISSAN ALTIMA
STAN7226
Steering problem
1998 Nissan Altima 4 cyl Two Wheel Drive Automatic
Is there a key release switch for this car
Dec 24, 2009 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check these tips out at https://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
If your steering column has a small access panel on the bottom, pop it off. Locate "plunger" (button, etc.) just inside the hole and slightly to the left.
If there is not a small removeable plastic piece, remove the housing around the steering wheel (this may require removing a few screws), and look for a white button directly under the steering wheel.
Hold it down and the key will turn with ease.
Dec 24, 2009 at 1:39 PM
