1995 Nissan Altima What is this noise???
DGPURPLE95
  • 7 POSTS
Noises problem
1995 Nissan Altima 4 cyl Front Wheel Drive Automatic 117K miles
For the last 2 or 3 months I have had a strange rattling/whining noise coming from the front of my car. When the mechanics check, they say it's coming from the location of the oil pump/timing chain. Also as I am driving, I hear this whining noise in the gas pedal. All of this calms down (not completely) after the car is warmed up. I have had just about everything replaced: chain (and all the accessories with it), oil pump, timing cover, water pump, etc. Except for the engine itself, all the parts under the hood are new.
The latest is that others have listened and thought the noise could be the idler pulley. I did the wd-40 test, and the noise disappeared and came back. When the mechanic took the belts off (left the pulley on), the noise was still there. I checked again with others and they suggested the noise was coming from the timing chain sprocket. Someone else suggested the timing chain guide. Took back to the mechanic and he said that when he had the car before he checked all that. Everything was fine. He even replaced the bearing for the sprocket.
It has now been about 6 months with this noise and still no relief!! PLEASE!!! Can someone help me figure out this awful noise?????
May 13, 2009 at 12:48 AM
RACEFAN966
  • 5,029 POSTS
Has the timing chain tensioner been checked. It may not be holding the chain tight enough?
Jun 8, 2009 at 6:43 AM
DGPURPLE95
  • 7 POSTS
Yes, the tensioner has been checked. The chain is on tight enough.
Jun 8, 2009 at 7:18 AM
RACEFAN966
  • 5,029 POSTS
Ok so we know for sure that the tensioner is hold the pressure under a load? Have you use an automotive stethiscope or long screwdriver (hold the handle end up to your ear and the other part on the part or location of the noise) to listen to the engine to pin point the exact location of the noise? You can put it on the alternator or the bolt on an idle pulley or the power steering pump etc and listen to them and pin the location of the noise. Let me know what you find.
Jun 9, 2009 at 2:51 AM
DGPURPLE95
  • 7 POSTS
Thank you for your ideas. I think I am going to have to go to the nearest Nissan dealership so they can do a diagnostic and try to help me find the problem. I'll let you know what comes out of that.
I have attached a link of the noise I recorded this morning. Hopefully it came out well enough for you to hear it. If not, let me know and I can redo it.
http://www.youtube.com/watch?v=LVoshc89o6Y
Jun 9, 2009 at 4:07 AM
RACEFAN966
  • 5,029 POSTS
OK I hear several things. I hear a power steering pump growling. I hear an exhaust leak and with it infront of me with a stethescope it sound like the timing chain is very loose and hitting the cover and the cam sounds like it might be trying to seaze (gualded cam jurnals) and if I heard right it sounded like it backfired? My question is what the timing chain grears and tensioner replaced or just inspected? If it was just inspected that really don't tell the story about what it is doing once it is moving and the tensoiner has the pressure on it. Let me know about the replacement or inspection of the timing components. If you look over the pic you see the cam chain on top but below is the main timing chain and that is what I think is causing all the noise. I would have replaced it all as I think the tensioner on the main (long) chain is allowing the chain to jump around and so you are heaing it hitting the guide on that side. Here is the pic of what I would have replaced.
https://images.2carpros.com/forum/automotive_pictures/249564_58222_1.jpg
Jun 10, 2009 at 2:36 AM
DGPURPLE95
  • 7 POSTS
Thankfully the car does not backfire. It may have been a finger brushing over the mic. As for the timing chain, the tensioners were replaced when the timing chain was replaced. The bearing for the sprocket was replaced, and the upper guides were recently removed.
Others who heard the noise said it could possibly be the idler pulley. We tested that theory by spraying wd-40 or silicone spray on it, and the noise went away. Once it dried it came back. Took it to the mechanic and he took the belts off and left the pulley on, and the noise was still there, so we never replaced the pulley.
I think this week I'll be going to Nissan to have them check it out. Hopefully the diagnostic will tell me what's the next step. Please, in the meantime, if you have other suggestions, I'm willing to hear them! Thanks
Jun 10, 2009 at 3:37 AM
RACEFAN966
  • 5,029 POSTS
Well the noise is in the front from what I can hear and it sounds like it could be in the timing or cam area. Now I do have a question has the oil pressure ever been checked for actual pressure with a test guage? If not it would be worth checking.
Jun 11, 2009 at 3:12 AM
DGPURPLE95
  • 7 POSTS
Everyone else I have spoken with so far say it's in the front fo the car. A few say it's still in the timing chain area. The rest are still liking the idler pulley theory.
The oil pressure has been checked recently, and with a test gauge. The last mechanic who had my car couldn't give it back to me because it had strangely lost oil pressure. This was after he had replaced the oil pump (he thought that was the cause of the noise). After some messing around with it, he was able to get the pressure back. Of course, the noise was still there.
Jun 11, 2009 at 8:54 AM
RACEFAN966
  • 5,029 POSTS
I do not support the idler pulley theory because you said you removed all the drive belts and started so the pulley would no longer be moving therefore it can not make noise, or at least it shouldn't. Now if you feel it is the idler pulley then pull it off and spin it in your hand and feel the bearing for roughness and listen to it for noise.
Jun 12, 2009 at 2:09 AM
DGPURPLE95
  • 7 POSTS
Well, my car is now at a Nissan dealer by me being checked out. They could not pinpoint the location of the noise other than the front area of the car. This diagnosis is after the car was apart. They are almost as frustrated as I am right now. While they have the car open they will replace a few things that look a bit worn (tensioner, guides), and hope that the noise goes away, or at least is not as loud. So far the only constant is pretty penny I am paying out each time the car is opened up...
Another option the mechanics at Nissan gave me was to replace the engine with a 'pre-man' engine, in the event the first option of replacing the parts doesn't work. With this second option comes much more money to shell out that I just don't have. I'm ready to pull my hair out!!!
Aug 28, 2009 at 1:33 AM
MOSVALVE
  • 6 POSTS
Purple,I have a '97 Altima that is making this same noise you describe. my mech. tightened the timing chain & the noise is still there . He thought harmonic balancer; but checked out ok. It does not seem to be oiling properly. Like you, I am frazzled. This car ran perfectly up to 192 K miles , then this noise started. He is recommending engine replacement, I just dont know at this point. Sorry for your woes, but you're not alone !
Sep 3, 2009 at 5:49 PM
DGPURPLE95
  • 7 POSTS
Well, I got my car back from the Nissan dealership and IT IS FIXED!!! It turned out it was the tensioners and guides (that had been replaced before!!) that were causing the dreaded noise! They told me that sometimes the after-market parts aren't always the best, and might have been the cause. I'm just glad that this part of my saga is OVER!!
For you, I hope you haven't been putting too much money into yours as I have in mine. I wish I could tell you how to fix it so you don't have to go through almost 9 months of headache like I did. Make sure everything in the chain area has been replaced, and maybe see if there is something wrong with the oil gauge (I hear that can be something that causes the noise). I was also told that the idler pulley might be a culpret (just not in my case); it's worth a shot. I would get a second opinion before paying for a new engine. Mine would have cost almost $4,000!!!
I hope you can get your car fixed. Altimas are great cars, especially the older models like ours! Good Luck to you!!
Sep 4, 2009 at 1:24 AM
