1995 Nissan Altima car wont start
JTRYON1989
  • 1995 NISSAN ALTIMA
  • 4 CYL
  • FWD
  • MANUAL
  • 108,000 MILES
My car just died on me one day when I was driving home. White smoke was coming out my valve cover gasket. I had a couple of mechanics take a look at it and said it might be a blown head gasket. My friend whois another mechanic took the valve cover off and there was no water in my oil so he didnt think it was blown. But just the seal was bad. So we changed the seal, oil, spark plugs and wires. It would not crank over for nothing. What might be stillwrong with it. It has a new battery in it 2 but we I turnedthekey all my lights dimmed down. So I tried jumpstarting it 2help. It didnt do anyhelp the lights still dimmed down.
Tuesday, November 25th, 2008 AT 9:39 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Hi, you need to make sure the engine turns over manually. If the engine is locked up the starter will make the headlights dim.
Thanks for using 2carpros. Com
Tuesday, November 25th, 2008 AT 5:10 PM
JTRYON1989
  • 9 POSTS
It cranks over. I removed the 1st spark plug and turned the key. It cranks but it spits out a coolant/oil mixture. Do you think it is a cracked head or the head gasket. How would you tell.
Saturday, December 6th, 2008 AT 7:19 AM
KEN L
  • 48,363 POSTS
Hi, the head gasket is probblby bad, follow this link fo more info.
http://www.2carpros.com/first_things/white_smoke_steam_exhaust.htm
let me know if you need anything else. Thnaks for using 2carpros.com
Sunday, December 7th, 2008 AT 2:23 PM
