1995 Nissan Altima Code 720
Service Writer, Rasmataz, or anyone out there, got any info on the Nissan speed sensor harness or what might cause a repeated failure? Help!
Capnjim
Okay-1st thing to do is scan the data of these sensors: Throttle Position, and Coolant Temperature this two deals with the overdrive and throttle pressure.
Dunno about Nismo having 2 sensors one @ the tranny and the other is at the speedo head at the dash.
Sometimes if the VSS is not align properly when installed it will fail. You need to investigate thoroughly at the tranny-pull it back out and look at the gear mechanism and ensure its all the way in and align before tighten it down.
To test it -take the sensor out -put key in On spin the sensor the speedometer should fluctuate if the wire is good and sensor. It produces an A/C signal this is what the computer is reading.
Good Luck!
Suggested Repair
Scan throttle position and coolant temperature data, since both affect overdrive and throttle pressure. Recheck the transmission speed sensor installation: remove it, inspect the gear, and reinstall it fully seated and aligned before tightening. With the key on, spin the removed sensor; the speedometer should fluctuate if the sensor and wiring are good, confirming the AC signal the computer reads.
Conversation Summary
A 1995 Nissan Altima with about 110,000 miles repeatedly sets code 720 and shifts erratically or stays in first after the transmission speed sensor is replaced. The owner suspects the harness or an electrical problem. The expert recommends checking throttle position and coolant temperature data, verifying sensor alignment and gear engagement at the transmission, and spinning the sensor with the key on to confirm that the wiring and AC signal make the speedometer fluctuate.
