THE PRIMARY FUNCTION OF YOUR BATTERY IS TO TURN YOUR STARTER. REMOVE THE STARTER AND TAKE IT TO AUTOZONE, OR ANY PARTS PLACE. THEY WILL TEST IT FOR FREE! I WILL GUESS AND SAY THAT YOUR START SHAFT WILL NOT EXTEND AS NEEDED TO ENGAGE THE FLYWHEEL IF IT EVEN ROTATES AT ALL.
NOTE: DID YOU CK YOUR FUSES? MIGHT DO THAT BEFOR REMOVEING THE STARTER, HOWEVER IT SOUNDS LIKE A STARTER PROB
ONE OTHER THING ARE YOUR BATTERY CABLES CLEAN AND CORRECTALLY CONNECTED BOTH ENDS?
SPONSORED LINKS
Wednesday, April 30th, 2008 AT 1:02 PM
